At Diamond we're currently using several motor controllers, including
the OMS (58 and MAXv), the Delta Tau PMAC (PMAC2-VME, Geobrick) and the
Newport XPS.
The motor record has a field called ATHM, which is set to 1 when the
motor has hit a home switch.
The OMS and Newport drivers use this field correctly, in that ATHM is
set to 1 when the motor is at home position (and is 0 otherwise).
However, the PMAC driver retains the ATHM status when moving away from
the home position - it actually means 'homed' for this driver, rather
than 'at home'.
Most of the motor control at Diamond is performed using the PMAC driver,
so everyone here has become used to this convention. It is arguably more
useful to have a 'homed' status, rather than 'at home'. Especially since
the 'at home' status can be inferred from the position (once it is homed
of course).
Is it the case that every other driver apart from the PMAC driver obeys
the ATHM status? I was considering changing the XPS driver to bring it
in line with the PMAC driver (for the benefit of our beamline users
mainly). However, if every other motor controller driver out there obeys
ATHM, then changing another one to do something different probably isn't
ideal. In this case, we'll probably just leave it as it is.
Any thoughts on this? Or info on other motor controller drivers?
Matthew
Dr Matthew Pearson
Software Systems Engineer
Diamond Light Source Ltd
Diamond House
Chilton, Didcot
OX11 0DE
Tel: +44 (0)1235 778538
(58
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
</FONT></DIV>
- RE: Motor home status Mark Rivers
- Re: Motor home status Ron Sluiter
Re: EPICS Gateway question Ralph Lange
Re: EPICS Gateway question Martin L. Smith
<2008>
"device clear" in asyn/Gpib support. Noboru Yamamoto
<2008>
