Hi Kevin,
I assume that the description you are quoting is ambiguous or not exact.
From my understanding, the server post rate is measured after splitting
up and partly duplicating the event stream to multiple clients of the
gateway. I.e. if the gateway looks at one channel at 1Hz and has two
clients watching that channel, the server event rate will be one, the
server post rate will be two.
You could set up a mini gateway and pull up two commandline camonitors
to check the logic behind those rates.
I think you're fine. I hope.
Cheers,
Ralph
Kevin Tsubota wrote:
Iâm working on deployment of an EPICS Gateway version 2.0.3.0 in our
system here. I have the gateway running on a solaris-8 computer built
against EPICS R3.14.9 with gcc 3.3.6. The gateway is serving 2
VxWorks IOCs on a separate VLAN running EPICS R3.13.10 and VxWorkd 5.3.1.
According to the following description for serverPostRate:
> This is the rate in Hz at which events are posted to CAS. If the
Gateway is keeping up, this will be very close to the serverEventRate.
If not, it will be higher and all posted events will not have been
processed.
Itâs not good when the serverPostRate is higher than the
serverEventRate. When I look my gateway stats I see that my
servoPostRate is a lot higher than my serverEventRate, sometimes by as
much as 2x, see attached gateway_rates.pdf. The data was logged once
every 10sec. My load and cpu frac seems okay, see attached
gateway_load.pdf.
Is there a way see whatâs causing this and what can I do about it?
Thank you in advance.
Kevin Tsubota
W.M. Keck Observatory
- RE: EPICS Gateway question Kevin Tsubota
- EPICS Gateway question Kevin Tsubota
"device clear" in asyn/Gpib support. Noboru Yamamoto
Motor home status Pearson, MR (Matthew)
<2008>
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
