Subject: "device clear" in asyn/Gpib support.
To: [email protected]
Date: Wed, 13 Aug 2008 16:03:57 +0900
I have a device through vxi-11 over ethernet.
I need to send "device clear" message/command to this device to
cancel an operation.
I use an asyn/GP-IB/vxi-11 based device support and set gpib command table entry as:
{&DSET_BO, GPIBDCL, IB_Q_HIGH, NULL, NULL, 0, 0, NULL, 0, 0, NULL, NULL, NULL }.
This setup send a DCL universal command to the device through vxi-11 "device_docmd" rpc function.
Unfortunately, our device does not support this method. The device just accept "device_clear" rpc call but not "DCL universal command".
In the current asyn package, each IFC and REN has an entry in an asynGpibPort structure, but DCL(Device Clear) is treated as one of universal commands.
It would be possible to introduce a new entry in asnyGpibPort for DCL
and call "device_clear" rpc function in the handler for vxi-11.
But I'm not quite sure if it does not break existing applications.
I would appreciate any comments or suggestions to solve this problem.
Thank you for reading this message.
Noboru Yamamoto
EPICS group, Acclerator Lab.
KEK, JAPAN
Prev: EPICS Gateway question Kevin Tsubota
Next: Re: EPICS Gateway question Ralph Lange
Prev: Re: EPICS Gateway question Dirk Zimoch
Next: Motor home status Pearson, MR (Matthew)
