Subject: EPICS Gateway question
To: <[email protected]>
Date: Tue, 12 Aug 2008 10:27:39 -1000
I’m working on deployment of an EPICS Gateway version 2.0.3.0 in our system here.  I have the gateway running on a solaris-8 computer built against EPICS R3.14.9 with gcc 3.3.6.   The gateway is serving 2 VxWorks IOCs on a separate VLAN running EPICS R3.13.10 and VxWorkd 5.3.1.
According to the following description for serverPostRate:
> This is the rate in Hz at which events are posted to CAS. If the Gateway is keeping up, this will be very close to the serverEventRate. If not, it will be higher and all posted events will not have been processed.
It’s not good when the serverPostRate is higher than the serverEventRate. When I look my gateway stats I see that my servoPostRate is a lot higher than my serverEventRate, sometimes by as much as 2x, see attached gateway_rates.pdf.  The data was logged once every 10sec.  My load and cpu frac seems okay, see attached gateway_load.pdf.
Is there a way see what’s causing this and what can I do about it?
Thank you in advance.
Kevin Tsubota
W.M. Keck Observatory
Attachment: gateway_rates.pdf
Description: gateway_rates.pdf
Attachment: gateway_load.pdf
Description: gateway_load.pdf
Re: EPICS Gateway question Ralph Lange
Re: EPICS Gateway question Martin L. Smith
Re: EPICS Gateway question Dirk Zimoch
Prev: Re: Scan Time Definitions Andrew Johnson
Next: "device clear" in asyn/Gpib support. Noboru Yamamoto
Prev: RE: asyn driver question: raw socket support Mark Rivers
Next: Re: EPICS Gateway question Ralph Lange
