Subject: Re: Scan Time Definitions
To: [email protected]
Cc: David Dudley <[email protected]>
Date: Tue, 12 Aug 2008 09:04:30 -0500
hi David,
On Monday 11 August 2008 19:00:08 David Dudley wrote:
> I've got some fields that only need to be scanned once a minute, once
> an hour, once every 4 hours, once every 12 hours, and once each night at
> midnite (actually, 24 hours from the last scan).
> These are for compliance reporting information, the information comes
> from remote sites, and it takes some time (a minute or so) to get each
> of the hourly readings.  I'd rather not scan these when I don't have to,
> and it would make more sense to admin if I could say "I scan this once
> every 4 hours" instead of "I scan this once every 14,400 seconds".
We have a subroutine record in all our vxWorks IOCs that generates a "console
chime" at a programmable period; in our case it prints a new prompt on the
vxWorks console with the current time at the top of every hour like this, so
that we can see in the console log when any error messages were generated:
2008-08-12 01:00   iocmcr1>
2008-08-12 02:00   iocmcr1> 0xc6f638 (METASYS Ch1): Wrong Sequence Number -
Expected 1397, Got 1395
0xc6f638 (METASYS Ch1): Wrong Sequence Number - Expected 1397, Got 1396
2008-08-12 03:00   iocmcr1>
2008-08-12 04:00   iocmcr1>
2008-08-12 05:00   iocmcr1>
You might want to re-use my subroutine code (attached) but replace the chime
printf() with something like post_event(prec->b) to generate a soft event at
the relevent period which will then trigger any records with SCAN=Event and
EVNT=<n> on that IOC.  You can then instantiate as many of these records as
you need periods, just set A to the period in minutes and B to the event
number.
HTH,
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
/* $Id: consoleChime.c,v 1.1 2005/01/07 22:36:08 anj Exp $ */
/* consoleChime field usage:
 *  A = chime period in minutes, defaults to 60 if not set
 *  L = timestamp (secPastEpoc) when we last chimed
#include <stdio.h>
#include <sysLib.h>
#include <shellLib.h>
#include "epicsTime.h"
#include "subRecord.h"
#include "registryFunction.h"
#include "epicsExport.h"
static char prompt[20];
static long consoleChimeInit(subRecord *psub)
    epicsTimeStamp now;
    if (psub->a < 1.0) psub->a = 60.0;  /* Default to chiming hourly */
    epicsTimeGetCurrent(&now);
    psub->l = now.secPastEpoch;
    sprintf(prompt, "%.13s> ", sysBootParams.targetName);
    shellPromptSet(prompt);
    return 0;
static long consoleChime(subRecord *psub)
    epicsUInt32 period, next;
    epicsTimeStamp now;
    if (psub->a < 1.0) psub->a = 1.0;   /* Chime at most once a minute */
    period = 60 * (epicsUInt32) psub->a;
    next = period * (1 + (epicsUInt32) psub->l / period);
    if (now.secPastEpoch >= next) {    /* Bong bong bong bong */
        char out[21];
        epicsTimeToStrftime(out, 20, "%Y-%m-%d %H:%M", &now);
        printf("\n%s   %s", out, prompt);
    return 0;
static registryFunctionRef consoleChimeRef[] = {
    {"consoleChimeInit",(REGISTRYFUNCTION)consoleChimeInit},
    {"consoleChime",(REGISTRYFUNCTION)consoleChime}
static void consoleChimeRegister(void)
    registryFunctionRefAdd(consoleChimeRef,NELEMENTS(consoleChimeRef));
epicsExportRegistrar(consoleChimeRegister);
record(sub, "$(IOC):consoleChime") {
	field(DESC, "Print time on IOC console")
	field(INAM, "consoleChimeInit")
	field(SNAM, "consoleChime")
	field(SCAN, "10 second")
	field(PRIO, "LOW")
Scan Time Definitions David Dudley
Prev: Re: Scan Time Definitions David Dudley
Next: EPICS Gateway question Kevin Tsubota
Next: asyn driver question: raw socket support Burkhard Kolb
