Subject: asyn driver question: raw socket support
To: "'[email protected]'" <[email protected]>
Date: Tue, 12 Aug 2008 13:47:11 +0200
we have bought some Lambda Gen 8-180/LAN power supplies, which look from the documentation "practically" the same as the power supplies from Agilent.
Nevertheless they use as low level protocol their private raw socket interface, which involves fiddling with the packet headers, etc.
How difficult would it be to implement this as an alternative to TCP and UDP in a port driver, given a programming example provided by Lambda?
The example code has basically a connect a send and a receive routine.
Any suggestions?
Burkhard
Dr. Burkhard Kolb
KP1 / GSI
E-Mail: [email protected]
Tel: +49-(6159)-71-2667 / Fax: +49-(6159)-71-2185
Gesellschaft für Schwerionenforschung mbH
Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführer: Professor Dr. Horst Stöcker
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
RE: asyn driver question: raw socket support Mark Rivers
Prev: Re: Scan Time Definitions Maren Purves
Next: RE: asyn driver question: raw socket support Mark Rivers
Prev: Re: Scan Time Definitions Andrew Johnson
