Subject: Re: Scan Time Definitions
To: "Allison, Stephanie" <[email protected]>
Cc: David Dudley <[email protected]>, [email protected]
Date: Mon, 11 Aug 2008 21:37:52 -0400
As much as I would consider adding scan "60 second", and that seems human readable enough, I would ponder on SCAN="4 hours": when you get the sample would depend on iocInit time, not necessarily the intented purpose?
It sounds like a problem SNL would better address, schedule something to happen at midnight, 4 am etc.
Allison, Stephanie wrote:
The SCAN field is an enum-type. You can alter epics-base and extend the range of options, but it will remain enum. Are you refering to another mechanism? 'seq' records allow specifying arbitrary delay DLY<n> when to process OUT<n> links, but that's also in seconds.
Even though SCAN is enum, the scan task finds the # of seconds (which it uses to delay between cycles) from the menu ASCII name using strtod (see 17.3.1 of the App Dev Guide). This is unusual. It would be nicer if menuScan.dbd had 3 fields for every option - the enum value (index number), the user-friendly name, and the "raw" name which is used by the scan task. But this is a change to epics base and probably not worth the effort.
Stephanie Allison
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
RE: Scan Time Definitions Erik Johansson
Scan Time Definitions David Dudley
Re: Scan Time Definitions Matthieu Bec
RE: Scan Time Definitions Allison, Stephanie
Prev: RE: Scan Time Definitions Allison, Stephanie
Next: RE: Scan Time Definitions Erik Johansson
