soft links for the O.<$EPICS_HOST_ARCH> directories
John Hammonds wrote:
I don't know of a way to do this but NFS could easily be used to
restrict user access to the source tree this if the machine that you
build from is not available or commonly used by the users. On the
machine hosing the NFS share change /etc/exports to look something
like this
/usr/local/epics my.compile.node(rw) *.my.domain(ro)
This allows only my.compile.node to change things. Make sure to add
in other common options (like no_root_squash) if needed.
David Dudley wrote:
Is there a way to setup the build system so that the
O.<$EPICS_HOST_ARCH> directories are in another location?
I'm building for 3 different architectures, and I'd like to put the
EPICS source on a single (hopefully!) write protected NFS server, and
link to it when I need access to build, but would rather not have the
client machine writing directories on the server if I can get away with
it.
David
- Re: Build Question Andrew Johnson
- Build Question David Dudley
- Re: Build Question John Hammonds
<2008>
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
