Subject: Re: Problems getting the Python module to work
To: Adam Kadzban <[email protected]>
Cc: [email protected]
Date: Wed, 06 Aug 2008 14:21:11 -0500
OK. So, the problem is that when EpicsCA was built it did not find the libca nor libCom and so they are not linked. Setting LD_LIBRARY_PATH now won't help since EpicsCA has already been compiled (right?)
/usr/local/EpicsFA2.1.5/build/lib.linux-x86_64-2.5 is where it is initially built and then it is copied over to /usr/lib/python2.5/site-packages
I would try to re-build EpicsCA...
First, remove the "build" directory. Next make sure LD_LIBRARY_PATH like was mentioned in the previous emails. Make sure the EPICS_BASE environment variable set as in the instructions.
Run python setup.py install. Then run ldd on the _epics.so files. Make sure that they are the new ones (check the date and time of the files "ls -l").
If the python install works the one in the build and site-packages directory should be identical.
See of this works. If ldd _epics.so still shows that it can't find libca and libCom, it won't work.
Save all the output to a file and send it to us.
Nino
Adam Kadzban wrote
It doesn't seem to be LD_LIBRARY_PATH. I tried setting it with export, and also putting it in the /etc/environment file.
There are two _epics.so files that 'locate' brings up, one in /usr/lib/python2.5/site-packages and one in /usr/local/EpicsFA2.1.5/biuld/lib.linux-x86_64-2.5. When I call 'ldd' on them, both say that libca.so and libCom.so are "not found". The other files they're linked to come up with hex addresses. I can't just stick "/usr/local/lib/epics/base/lib/linux-x86_64/libca.so" in there, so how do I link those in?
"When you built it, there should have been a gcc line that includes something like -lca and -lCom... try using the direct path to libca and libCom, i.e.,
/usr/local/lib/epics/base/lib/linux-x86_64/libca.so. It's the gcc line that build _epics.so, I believe."
I remember seeing -lca and -lCom come up when I was installing the epics base. Should I dig around the epics base files and try to find that line? I'm not sure where in there to look...
-Adam
On Wed, Aug 6, 2008 at 1:50 PM, John Hammonds <[email protected] <mailto:[email protected]>> wrote:
    This should be LD_LIBRARY_PATH.  You were able to find epicsCA
    which is the Python part of things.  libca is the epics library
    which does not have anything to do with Python.
    Also, for what it is worth, I have also been working to update
    Geoff Savage's CaPython.  This does not provide quite as slick an
    interface as Matt's but it is  a pretty full implementation of the
    Channel Access Libraries.  I have most of this working using a
    newer version of SWIG and python.  I have not yet added the 3.14
    CA calls but it can do things like deal with larger arrays.  I am
    trying to coordinate with Geoff before releasing this.
John
Tim Mooney wrote:
        Adam,  The first thing I'd try is setting either the
        LD_LIBRARY_PATH,
        or the PYTHONPATH, environment variable to the directory
        containing the
        needed .so file.  E.g.:
        setenv LD_LIBRARY_PATH /usr/local/lib/epics/base/lib/linux-x86_64
          or, if you're using bash,
        export LD_LIBRARY_PATH=/usr/local/lib/epics/base/lib/linux-x86_64
Adam Kadzban wrote:
            Hey all, I'm a relative newcomer to both Linux, Python,
            and Epics, so sorry if this has an easy solution.  I guess
            I'm not even sure if it's a problem with Epics itself, or
            Python, or something else.  I'm having some problems
            getting Python to import the EpicsCA module.  I'm running
            Ubuntu 8.04 (Hardy), and it's an x86_64 system.  The epics
            base seems to have installed fine, I put it in
            /usr/local/lib/epics/base.  I got the epics module here
            <http://cars9.uchicago.edu/%7Enewville/Epics/Python/>
            (http://cars9.uchicago.edu/~newville/Epics/Python/
            <http://cars9.uchicago.edu/%7Enewville/Epics/Python/>),
            and again it looked like it installed fine to
            /usr/local/EpicsCA-2.1.5.
            The problem is, whenever I try to do anything with EpicsCA
            in Python, it dies on me because it can't find libca.so.
             Here's what it shows when I try to import EpicsCA:
             >>> import EpicsCA
            Traceback (most recent call last):
             File "<stdin>", line 1, in <module>
             File
            "/usr/lib/python2.5/site-packages/EpicsCA/__init__.py",
            line 116, in <module>
               import _epics
            ImportError: libca.so: cannot open shared object file: No
            such file or directory
(it does the same if I try "from EpicsCA import *")
However, I know libca.so exists, it's here:
            adam:$ locate libca.so
            /usr/local/lib/epics/base/lib/linux-x86_64/libca.so.3.14
            /usr/local/lib/epics/base/src/ca/O.linux-x86_64/libca.so.3.14
            So there it is, in the epics base folder.  Why can't
            Python find it?  I was digging around online, and found
            how to add places for Python looks for modules to import
            them (though I don't think that's the problem, because it
            can't find libca.so, not a module), and I added a bunch of
            places, to no avail.  Anyone have any ideas?
Not sure if it's relevant, but when I ran the setup.py script to install EpicsCA, I had to edit the environment variable manually. I added "EPICS_BASE=/usr/local/lib/epics/base" to /etc/environment, but for some reason os.environ['EPICS_BASE'] wasn't finding /usr/local/lib/epics/base. I had to change the setup script to look there. Though if I opened a Python interpreter and printed os.environ['EPICS_BASE'], it came out as /usr/local/lib/epics/base. So something fishy was going on there, not sure if it's related though.
Thanks, Adam Kadzban
-- John Hammonds
Beamline and Data Acquisition Group
APS Engineering Support Division
    Argonne National Laboratory
    <mailto:[email protected] <mailto:[email protected]>>
    (630)252-5317
Re: Problems getting the Python module to work Adam Kadzban
Re: Problems getting the Python module to work Tim Mooney
Re: Problems getting the Python module to work John Hammonds
Prev: Re: Problems getting the Python module to work Adam Kadzban
Next: Re: Problems getting the Python module to work Adam Kadzban
