Subject: Re: Bergoz LR-BPM Monitoring system for LINAC
To: "K.M Ha" <[email protected]>
Cc: [email protected]
Date: Wed, 06 Aug 2008 07:01:25 +0900
Hello,
>>> On Mon, 04 Aug 2008 12:03:51 JST,  "K.M Ha" <[email protected]> wrote;
> Dose any one has an experience of Bergoz 500 MHz LR-BPM for the Linac Beam
> position monitoring?
> Our Linac installed over 20 sets LR-BPM on the BTL section.
> Now we are consider how to integration of monitoring system. (ex, ADC board,
> external trigger or beam trigger .)
Once we tried Bergoz (200MHz or 500MHz), but we had difficulties in
the hardware stabilities and triggering, etc.  (And I've heard a
rumor he retired?)  Also, we wanted to read each electrode for the
beam charge as well as the position, and for the higher-order beam
profile analysis.  Instead, at KEK Linac we decided to utilize
Windows/EPICS embedded oscilloscopes DPO7104, directly connected to
the BPM signals, which enables 50Hz read-out as well.  You may loose
a precision and/or a dynamic range, which can be important for FEL
machines, etc.  But for the BT line it may be OK.  If the bunch is
short or single, one oscilloscope may cover many BPMs in time
direction with rf combiners.
Another solution which employed log. amp. like Bergoz but with 3GHz
was done at Spring8.
> I am waiting any help!
Sorry for no direct answer.  Best regards.
> Thanks,
> Kiman Ha,
> Pohang Light Source
Kazuro FURUKAWA <[email protected]>
 Linac&KEKB,  High Energy Accelerator Research Organization (KEK), Japan
 Telephone: +81-29-864-5200 x4316,  Facsimile: +81-29-864-0321
Bergoz LR-BPM Monitoring system for LINAC K.M Ha
Prev: RE: EPICS to Python / EPICS to Tcl Rowland, J (James)
Next: Re: Gated ADC Kazuro FURUKAWA
Prev: Bergoz LR-BPM Monitoring system for LINAC K.M Ha
Next: RE: Bergoz LR-BPM Monitoring system for LINAC Solal
