Subject: RE: Gated ADC
To: "Kalantari Babak" <[email protected]>, "Leicester, PJ (Pete)" <[email protected]>
Cc: [email protected]
Date: Tue, 5 Aug 2008 08:23:30 -0500
Pete,
I am not clear on exactly what you want.  Do you want to 1) collect one sample per transition of the gate signal, or do you want to 2) collect data at a fixed clock rate but start and stop acquisition with a gate signal?  The IP-330 may do what you want, depending on what mode you use it in.  If mode 2) is what you want then you could always use some external logic to gate an external clock source off and on.
-----Original Message-----
From: [email protected] on behalf of Kalantari Babak
Sent: Tue 8/5/2008 5:49 AM
To: Leicester, PJ (Pete)
Hi Pete,
I think 8401 Hytec IP module together with 8002 or 8004 (supports BLT as
well) carrier is what you are looking for. Take a look at
http://www.hytec-electronics.co.uk/8401UTM_ISS12.pdf
It has all the features you mentioned. I would use the INHIBIT input as
the hardware gate. If the inhibit input is taken low the memory update
is stopped and an interrupt is invoked (if enabled).
We have a driver for waveform but it may require very little
modification only in the interrupt service routine to properly handle
memory inhibit interrupts.
Let me know if you need the driver.
Babak
[mailto:[email protected]] On Behalf Of Leicester, PJ (Pete)
Sent: Dienstag, 5. August 2008 10:20
To: [email protected]
Subject: Gated ADC
1) Data collection controlled by a hardware gate signal such that data
is collected into a buffer when the gate is enabled and when the gate is
disabled an interrupt is generated so the data can be transferred into
an I/O Intr processed waveform (or similar) record.
2) Sample rate up to at the least 10KHz but preferably 100KHz, and an
absolute minimum of 16 bit.
3) Epics support for waveform record (or MCA or similar).
4) Preferably packaged as an IP module but a VME card would be OK.
Note that the essential feature is the gating of collection on the
hardware signal. We do not want to trigger and collect a fixed number of
samples (most ADC's do this).
Any suggestions would be gratefully received.
RE: Gated ADC Leicester, PJ (Pete)
RE: Gated ADC Kalantari Babak
Prev: RE: EPICS to Python / EPICS to Tcl Rowland, J (James)
Next: RE: Gated ADC Graham Cross
Prev: RE: Gated ADC Kalantari Babak
Next: RE: Gated ADC Leicester, PJ (Pete)
