Subject: Re: EDM installation issues edmPvObjects, etc.?
To: Carl Schumann <[email protected]>, [email protected]
Date: Fri, 01 Aug 2008 12:58:39 -0400
Hi:
Read & try to use setup/setup.sh which creates that edmPvObjects file.
-Kay
[email protected] on 8/1/08 12:44 :
> Hello,
> I am trying to build and run edm.   I am using the instructions from
> "extensions/src/edm/README.install" that came in the tarfile.  I am to
> the following point in the instructions:
>>       As an example here is what we set at the SNS:
>>       -- EDMPVOBJECTS=$EPICS_EXTENSIONS/ext_pref/edm
>>       -- EDMOBJECTS=$EPICS_EXTENSIONS/ext_pref/edm
>>       -- EDMHELPFILES=$EPICS_EXTENSIONS/src/edm/helpFiles
>>       -- EDMFILES=$EPICS_EXTENSIONS/ext_pref/edm
>> EDMDATAFILES=./:$IOCTOP/<system1>/opi/edl:$IOCTOP/<system2>/opi/edl
>>       Also, we will make available the $EPICS_EXTENSIONS/ext_pref/edm
>> as an example.
>>       This will be tarred up as ext_pref-edm.tar on our ftp site:
>> (ftp://snsftp.sns.ornl.gov/UPLOAD/controls/edm)
>>       Some of the configuration steps may be discussed in the edm
>> documentation located
>>       in the following: $EPICS_EXTENSIONS/src/edm/doc
> I am having problems with the ftp site referenced above.  First, I got
> an access error, then when I tried again I did not get an access error
> but the directory was empty.   I was expecting to find an example
> edmPvObjects file.   Help would be appreciated?
> Thanks,
> Carl Schumann
EDM installation issues edmPvObjects, etc.? Carl Schumann
Prev: EDM installation issues edmPvObjects, etc.? Carl Schumann
Next: Re: EDM installation issues edmPvObjects, etc.? Kevin Anderson
