Subject: Re: DMA Example
To: [email protected]
Date: Mon, 21 Jul 2008 12:41:47 -0500
Hi Zen,
On Friday 18 July 2008 13:37:37 Szalata, Zenon M. wrote:
> I am trying to implement code to do DMA data transfer from a VME module to
> mv6100 local memory using vxWorks routines: sysTempeDmaStart and
> sysTempeDmaStatus.
I assume you decided not to use my tempeDma.c interface then, since these
routines are the ones from the code that comes with the mv6100 BSP (I don't
think the two will work together properly, so I hope you're not trying to
build a BSP with both included at the same time).  You may be the only person
in the EPICS community using that code.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
DMA Example Szalata, Zenon M.
Prev: Re: MAXv problem update EPICS record Ron Sluiter
Next: Re: VXI resource manger converted to R3.14? Andrew Johnson
Prev: DMA Example Szalata, Zenon M.
Next: How to introduce usage of genSub ? haquin
