Subject: How to introduce usage of genSub ?
To: [email protected]
Date: Mon, 21 Jul 2008 11:29:56 +0200
Hi all,
I want to use genSub record but I don't know how to make it available, I use EPICS 3.14.8.
My starting point is the example application obtained with :
>makeBaseApp.pl -t exampleApp myGenSubApp
>makeBaseApp.pl -i -t exampleBoot myGenSubApp
Here is What I did:
- In the <top>/configure/RELEASE file I have added the location of the gensub module (GENSUB=$(EPICS_BASE)/../modules/soft/gensub)
- then I run the make command in the <top> directory
=> When I inspect the application tree there is nothing related to the genSub, the genSub record is not available in VDCT.
As a first step I would like to do what is done in the example application with the sub record but with a genSub record.
Can someone explain me the procedure to have genSub available ?
Regards.
Re: How to introduce usage of genSub ? Tim Mooney
Prev: DMA Example Szalata, Zenon M.
Next: Re: array calc / inverse subarray survey? Luedeke Andreas
Prev: Re: DMA Example Andrew Johnson
Next: Re: How to introduce usage of genSub ? Tim Mooney
