Subject: Re: MAXv problem update EPICS record
To: [email protected]
Cc: [email protected]
Date: Fri, 18 Jul 2008 11:47:55 -0500
Hello Jerome,
Yes, there appears to be a bug in the motor record associated with setting
the state of the limit switch indicator (RA_HOME) in the MSTA field.
Currently, RA_HOME is not getting set in process_motor_info() if
EA_PRESENT and UEIP are true.  That's not right, RA_HOME should
be set unconditionally.
I'll contact you as soon as I get a patch on the motor record web site.
Thanks for the catching this,
Ron
jerome HOSSELET wrote:
Hi all,
I use a OMS MAXV4000/ MOTOR R 6.3 / EPICS base 3.14.9 / ASYN 4.9 / vxWorks 6.2 / CPU Motorola MVME5500-0161 - MPC 7457
My problem is :
On EDM , a status HOME is always on 0 . ( I click on STATUS but nothing change)
I check with a personnal SMV function
SMV("AX RA") REQUEST AXIS STATUS
I have this response
recv_mess(): card#0 - MNNH
MAXV>MNNH<
A driver see a HOME but on EDM nothing changed
i try to caget "IOC:m1.ATHM" but it s always on 0
(I think that EPICS record was not updated)
how resolv this BUGs !!!
thanks per advance
JEROME HOSSELET
Re: MAXv problem update EPICS record Ron Sluiter
MAXv problem update EPICS record jerome HOSSELET
Prev: RE: array calc / inverse subarray survey? Mark Rivers
Next: RE: Building 32-bit EPICS binaries on 64-bit Linux systems Mark Rivers
Prev: MAXv problem update EPICS record jerome HOSSELET
Next: Re: MAXv problem update EPICS record Ron Sluiter
