Hi
I’d like to do some array calculations (FFT,
rectangular to polar, filtering etc). I’d like the option to run at high
rates (KHz) which would suggest using asyn. Is there any standard for this? Some
possibilities are aCalcout, waveProc, genSub. If the waveform record had an
input and an output I could easily put the calculations in the asyn layer but I
can’t see an obvious way to build a processing chain with only one link.
Any suggestions?
Also is there a standard for inverse subarray? I’d
like to combine 100s of scalar PVs into one waveform.
Thanks
James
Senior Software Engineer
Diamond Light Source
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message. Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
- RE: array calc / inverse subarray survey? Mark Rivers
- Re: array calc / inverse subarray survey? Luedeke Andreas
Re: stdout being changed in EPICS Eric Norum
MAXv problem update EPICS record jerome HOSSELET
<2008>
RE: Building 32-bit EPICS binaries on 64-bit Linux systems Mark Rivers
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
