I've used several types in the Water system here, with various degrees
of success.
The Moxa NPORT series works great, and I've never had problems with
them. Also there are a set of devices from a company called SENA that
I've used successfully for quite a while.
I've used the DIGI units as well, and have had no significant problems
with them, with the possible exception of the DIGI-1 unit, which does
MODBUS/TCP, but sometimes has problems with my EPICS configuration. In
addition, I've used the Schneider Automation CE174 units successfully,
as long as you don't have too many host units attempting to link to it
(it has a limit of 8 concurrent links).
The versions I have used of all of these units are all single port.
Personally I most like the MOXA NPort IA5150-M-SC of which I have
several in the field. These are single port units that go directly from
100BaseFX to RS-232/ RS-485 in a single shot. They save quite a bit of
complexity in the hardware setup in the field.
David Dudley
>>> Maren Purves <[email protected]> 7/8/2008 3:09 PM >>>
Dave Reid wrote:
> Hi everyone...
> We are looking for an Ethernet-to-RS232 device that we can use in a
> manner similar to the Agilent GPIB gateway, meaning using ASYN to
send
> messages out over our network and then out to RS232 devices.
> Is anyone else doing this? Have a product that they've had good
results
> with or any to avoid?
Question: are you asking about terminal servers?
We have a bunch of Emulex terminal servers in use, for years already,
and with hardly any problems (occasional port hangups + ports losing
a setting or so, mostly after power failures).
Maren
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
- Ethernet-to-RS232 Dave Reid
- Re: Ethernet-to-RS232 Maren Purves
RE: Ethernet-to-RS232 Mark Rivers
Re: Ethernet-to-RS232 Graham Waters
<2008>
<2008>
