I should then implement a portion which checks the connection status
to the PV's, correct?
Bertrand
On Jul 6, 2008, at 12:57 PM, Andrew Johnson wrote:
I thought it has to do with the CA part due to the nature
of the error message. But I added in some more fclose statements and
will see if that removes the problem.
I think it's more likely because you're repeatedly calling
ca_context_create() and then ca_context_destroy(). Try moving those
calls outside the while loop so that you re-use the same context and
I suspect your problem will go away (CA probably only expects to be
used once within a single process context).
- Andrew
- Re: unable to create virtual circuit b/c "Too many open files" Andrew Johnson
- CAC: unable to create virtual circuit b/c "Too many open files" Bertrand H.J. Biritz
- RE: unable to create virtual circuit b/c "Too many open files" Mark Rivers
- Re: unable to create virtual circuit b/c "Too many open files" Bertrand H.J. Biritz
<2008>
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
