> I thought it has to do with the CA part due to the nature
> of the error message. But I added in some more fclose statements and
> will see if that removes the problem.
I think it's more likely because you're repeatedly calling ca_context_create() and then ca_context_destroy(). Try moving those calls outside the while loop so that you re-use the same context and I suspect your problem will go away (CA probably only expects to be used once within a single process context).
- Andrew
- Re: unable to create virtual circuit b/c "Too many open files" Bertrand H.J. Biritz
- CAC: unable to create virtual circuit b/c "Too many open files" Bertrand H.J. Biritz
- RE: unable to create virtual circuit b/c "Too many open files" Mark Rivers
<2008>
<2008>
