Subject: CAC: unable to create virtual circuit b/c "Too many open files"
To: [email protected]
Date: Sat, 5 Jul 2008 22:13:19 -0400
Dear Tech-talk,
I wrote a monitoring program using some of the example code from EPICS- BASE and the lecture videos. It connects to an IOC every 5 minutes for 12 PV's and write their values to a text file.
The only problem is that it eventually fails with the following error message:
epicsSocketEnablePortUseForDatagramFanout: unable to set SO_REUSEADDR?
epicsSocketDestroy: failed to close a socket because "Bad file descriptor"
CAC: unable to create virtual circuit because "Too many open files"
the last line is repeated multiple times.
Now the relevant code snippet is:
while(1)
       * Here is where the CA calls happen
/* Initialize */
 status=ca_context_create(ca_disable_preemptive_callback);
      if(status != ECA_NORMAL)
	  printf("ca_context_create failed:\n%s\n",ca_message(status));
	  exit(1);
/* Search */
for(i = 0; i < 12; i++)
status = ca_create_channel (pv[i],connectionChangedCB,NULL,CA_PRIORITY_DEFAULT,&pCh[i]);
printf("ca_create_channel for pv%d failed:\n%s\n", i, ca_message(status));
exit(1);
      /* Wait */
      startTime=curTime;
      ca_pend_event(timeout);
/* Clear the channel */
status=ca_clear_channel(pCh[i]);
printf("ca_clear_channel for pv%d failed:\n%s\n", i, ca_message(status));
/* Exit */
      ca_context_destroy();
I thought I had included everything I need, but apparently I missed something.
Any help would be greatly appreciated,
Bertrand
Happy post July 4th!
RE: unable to create virtual circuit b/c "Too many open files" Mark Rivers
Prev: Re: Epics DMA for the MVME6100 Andrew Johnson
Next: RE: unable to create virtual circuit b/c "Too many open files" Mark Rivers
Prev: CAEN VME V1724 8 Channel 14 bit 100 MS/s Digitizer Rose, AJ (Austen)
