I would like a copy of your driver code and instructions on how to use it, if possible.
Thanks for your help,
Zen
-----Original Message-----
Sent: Tuesday, July 01, 2008 3:09 PM
To: Szalata, Zenon M.
Cc: [email protected]
Subject: Re: Epics DMA for the MVME6100
On Tuesday 01 July 2008 15:40:34 Szalata, Zenon M. wrote:
> Yes, I failed to provide the crucial piece of information, which is
> that the board for which I am writing the device driver does not have
> a DMA controller built in; the DMA controller on the MVME 6100
> processor board is to be used. Thanks again,
Ok, so now you get to decide whether to use the sysTempeDma driver code that's provided with the mv6100 BSP (your code is then specific to the MVME6100 board), to install my driver into your BSP and write your code to my generic sysDma interface, or to port Till's RTEMS code and use that instead.
Note that my API only works it you're doing a memory-to-memory transfer, it doesn't provide a way to read data out of a single register into sequential RAM. Let me know if you want a copy.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: Epics DMA for the MVME6100 Andrew Johnson
- Epics DMA for the MVME6100 Szalata, Zenon M.
- RE: Epics DMA for the MVME6100 Szalata, Zenon M.
CAEN VME V1724 8 Channel 14 bit 100 MS/s Digitizer Rose, AJ (Austen)
<2008>
<2008>
