Subject: RE: asyn / stream for http:??
To: "Burkhard Kolb" <[email protected]>, <[email protected]>
Date: Fri, 27 Jun 2008 09:46:41 -0700
Burkhard,
We use streamdevice and asyn to monitor and control Wiener VME crates via a web interface.  We build streamdevice with support for regular expressions (PCRE) -- see http://epics.web.psi.ch/software/streamdevice/doc/setup.html#pre.  I will send you the database and streamdevice protocol files.
Stephen
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Burkhard Kolb
> Sent: Friday, 27 June 2008 7:56 AM
> To: '[email protected]'
> Subject: asyn / stream for http:??
> Hi,
> I have a set of network controlled power switches from Gude
> (www.gude.info).
> They support status readback and on/off and power cycle functions
> through a web interface. Unfortunately that is the only interface.
> The vendor also supplies a perl script which can parse the
> response from
> the web server. This looks almost like a protocol in streamDevice...
> Any advice on how to get this into EPICS records?
> Cheers,
> Burkhard
> Dr. Burkhard Kolb
> KP1 / GSI
> E-Mail: [email protected]
> Tel: +49-(6159)-71-2667 / Fax: +49-(6159)-71-2185
> Gesellschaft für Schwerionenforschung mbH
> Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
> Gesellschaft mit beschränkter Haftung
> Sitz der Gesellschaft: Darmstadt
> Handelsregister: Amtsgericht Darmstadt, HRB 1528
> Geschäftsführer: Professor Dr. Horst Stöcker
> Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
> Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
asyn / stream for http:?? Burkhard Kolb
Prev: Re: asyn / stream for http:?? J. Lewis Muir
Next: Is it possible to give parameters to the Startup script (st.cmd) haquin
