Subject: Question with sscan Record!
To: "'Tim Mooney'" <[email protected]>
Cc: [email protected]
Date: Thu, 26 Jun 2008 09:53:06 +0800
Hello:
I use sscan Record to drive 2 positioners synchronously.
When the 2 positioners scan mode are all TABLE, only positioner 1 can be scanned, it can move position by position as P1PA specified. positioner2 will move to 0, then stop. if I set positioner 2 to LINEAR mode, these 2 can both be scanned, 2 motors can move position by position synchronously.
I have specified P1PA and P2PA by
caput ?a IOC:scan1.P1PA 10 1000 2000 3000 4000 5000 6000 7000 8000 9000 10000
caput ?a IOC:scan1.P2PA 10 1000 2000 3000 4000 5000 6000 7000 8000 9000 10000
Could you tell me why positioner 2 cant move position by position like position 1 does when both in TABLE mode? Is there any problem with my db file?
The db file is like this:
record(motor, "$(P)m1"){
    field(SCAN, "Passive")
    field(DESC,"beijing 5phase motor")
    field(DTYP,"OMS MAXv")
    field(DIR,"Pos")
    field(VELO,"10000")
    field(VBAS,"4000")
    field(ACCL,"0.2")
    field(BDST,"0")
    field(OUT,"#C0S0@")
    field(MRES,"8")
    field(PREC,"0")
    field(EGU,"um")
    field(DHLM,"100000")
    field(DLLM,"-100000")
    field(VMAX,"15000")
    field(INIT,"AF")
record(motor, "$(P)m2"){
    field(DIR,"Pos")
    field(VELO,"10000")
    field(VBAS,"4000")
    field(ACCL,"0.2")
    field(BDST,"0")
    field(OUT,"#C0S1@")
    field(MRES,"8")
    field(PREC,"0")
    field(EGU,"um")
    field(VMAX,"15000")
    field(INIT,"AF")
record(sscan, "$(P)scan1") {
  field(DESC, "Scan 1")
  field(PINI, "YES")
  field(PRIO, "HIGH")
  field(MPTS, "10")
  field(FPTS, "FREEZE")
  field(FFO, "USE F-FLAGS")
  field(P1HR, "100000")
  field(P1LR, "0")
  field(P1PR, "0")
  field(P1PV, "$(P)m1.DVAL")
  field(P1SM, "TABLE")
  field(P1AR, "ABSOLUTE")
  field(P1EU, "um")
  field(R1PV, "$(P)m1.DRBV")
  field(P2HR, "100000")
  field(P2LR, "0")
  field(P2PR, "0")
  field(P2PV, "$(P)m2.DVAL")
  field(P2SM, "TABLE")
  field(P2AR, "ABSOLUTE")
  field(P2EU, "um")
  field(R2PV, "$(P)m2.DRBV")
  field(NPTS, "10")
  field(P1SP, "0")
  field(P1SI, "1000")
  field(P2SP, "0")
  field(P2SI, "1000")
  field(PDLY, "0.1")
likun
Beamline Control Group, SSRF, China
李坤
中国科学院上海应用物理研究所
控制组
电话:02133933238
email[email protected]
Re: Question with sscan Record! Tim Mooney
Prev: Re: latest motor record on RTEMS? Kate Feng
Next: Pulse Train Record David Dudley
Prev: Re: latest motor record on RTEMS? John M. Skinner
Next: Re: Question with sscan Record! Tim Mooney
