Hi,the hook for CA-Put-Logging are available in base for quite some time. The hook for alarm-logging has been added recently.
The hooks are only the mandatory part of this story. The real workhorse is behind the hooks. (and not part of base) So the answer is -no- it's not integrated into iocLog. Behind the alarm-hook is the alarmLogging task which is now in operation at DESY for about a year. Behind the CA-PutLog hook is the task which Slava Korobov wrote about a decade ago. As soon as there's time to work on this part we (Bernd) will have a look at the code for put-logging and use the same method as for alarmLogging to forward(push) the putLog messages to the interconnectionServer which finally writes messages into JMS. Besides the fact that we want to send all of the messages: alarms, putLog AND system messages into JMS there's another good reason to work on the putLogmessage task. Namely logging changes when one - or even worse - two or more operators are tuning a record using the slider. The actual implementation only covers the case where lots of changes are applied to the same PV(as a result only one message will be generated when the slider movement finished - here: another PV is accessed, or after a tineout). We want to improve this part of the code. The ring buffer which is already in place for alarmLogging can help us (probably a second instance of it) to keep track of bulk changes on several records in parallel. If there's interest to work together on this part - let us know. System logging shall finally also use the JMS message facility. The advantage being that all messages will be stored in one place. All the tools to display and analyze messages can be the same and last and most importantly we can also use the support for redundant connections which is built into the communication between IOC and interconnectionServer. (btw: there's also a C++ program in operation to replace cmlogMsg and write directly to JMS - on workstations) -Matthias
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
