Subject: Re: Visual C++ link errors
To: [email protected]
Date: Mon, 23 Jun 2008 18:11:49 -0500
On Monday 23 June 2008 17:43:43 Mark Rivers wrote:
> One possible source of the problem is that pdbbase should really be
> defined as follows, as it is done in db_convert.h:
> epicsShareExtern struct dbBase *pdbbase;
> However, motorUtilAux.cpp defines it as follows:
> extern "C" {
> extern struct dbBase *pdbbase;
The definitive declaration of pdbbase is in dbAccessDefs.h so you shouldn't
need to create your own declaration.  If the version in that header doesn't
work from C++ let me know and we'll fix it.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
RE: Visual C++ link errors Mark Rivers
Prev: RE: Visual C++ link errors Mark Rivers
Next: How to specify value to a DBF_ACCESS field likun
Next: Re: Visual C++ link errors Ron Sluiter
