The motor record has been written in C++ for many years, and I've been
using it under Windows with VC 7.1 and VC 8.0 for several years with no
problems.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Monday, June 23, 2008 5:15 PM
To: [email protected]
Subject: Re: Visual C++ link errors
On Monday 23 June 2008 16:33:49 Ron Sluiter wrote:
> Anybody got a clue as to why this doesn't link.
> Specs: Visual Studio 6.0 and 7.0, base-3.14.8.2, motorR6-2-2
> Creating library motor.lib and object motor.exp
> motorUtilAux.obj : error LNK2019: unresolved external symbol _pdbbase
> referenced in function "char * * __cdecl getMotorList(void)"
> (?getMotorList@@YAPAPADXZ)
> Apparently, pdbbase is not in dbIoc; "nm -A dbIoc.lib | grep pdbbase"
> yields no results.
pdbbase is defined in <base>/src/db, in dbAccess.c
Do you build the motor record using the C++ compiler? No other record
type
uses C++ for record implementation, so if you do you're the guinea-pig
here.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: Visual C++ link errors Andrew Johnson
RE: Visual C++ link errors Mark Rivers
<2008>
<2008>
