Subject: Re: Visual C++ link errors
To: [email protected]
Date: Mon, 23 Jun 2008 17:14:56 -0500
On Monday 23 June 2008 16:33:49 Ron Sluiter wrote:
> Anybody got a clue as to why this doesn't link.
> Specs: Visual Studio 6.0 and 7.0, base-3.14.8.2, motorR6-2-2
>    Creating library motor.lib and object motor.exp
> motorUtilAux.obj : error LNK2019: unresolved external symbol _pdbbase
> referenced in function "char * * __cdecl getMotorList(void)"
> (?getMotorList@@YAPAPADXZ)
> Apparently, pdbbase is not in dbIoc; "nm -A dbIoc.lib | grep pdbbase"
> yields no results.
pdbbase is defined in <base>/src/db, in dbAccess.c
Do you build the motor record using the C++ compiler?  No other record type
uses C++ for record implementation, so if you do you're the guinea-pig here.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
RE: Visual C++ link errors Mark Rivers
Visual C++ link errors Ron Sluiter
Prev: RE: Visual C++ link errors Mark Rivers
Next: RE: Visual C++ link errors Mark Rivers
