It took some minor persuasion, but I managed to get edm 1-11-1g (the latest version) to compile under Fedora Core 9. Unfortunately, the application is largely unstable. In particular, it crashes with a "Segmentation Fault" whenever I attempt to place a Menu Mux object. It also crashes rather frequently (but unpredictably) when I'm accessing the Help files (particularly when I close the files after viewing them). The Menu Mux object does appear in the window the instant before edm crashes. In addition, if I open an EDL file that contains a Menu Mux object, edm only crashes when I try to access the properties for the object. I installed openmotif-2.3.0-0.3.fc8.ccrma.i386.rpm and openmotif-devel-2.3.0-0.3.fc8.ccrma.i386.rpm initially, but have since tried openmotif-2.2.3-2.i386 and openmotif-devel-2.2.3-2.i386 with the same result. There's an older message on the list that suggests removing the devel packages, but the header files they contain appear to be necessary. Any suggestions as to what the problem might be? Regards, Kevin.
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
