Thanks, Dirk,
On Tue, Jun 17, 2008 at 8:46 PM, Dirk Zimoch <[email protected]> wrote:
> Hi Chen,
> we run into similar problems at the SLS recently. The problem is the
> difference between how we think array support should work and how it is
> actually implemented. All EPICS records which deal with arrays always copy
> buffers. Manipulating pointers is not supported!
I thought so. 'coz I have no problem with the ai or longin records. But I'm
not sure. Thank you for the detailed reason, it's very help.
> That means:
> Do not modify pwf->bptr. It simply does not do what you would expect.
> Reason:
> The value of pwf->bptr is read by channel access on connect only. Thus
> reading the same record multiple times (get or monitor) from the same
> application always reads the same buffer. Modifications of pwf->bptr after
> the client has connected have no effect. Thus, touching pwf->bptr after
> record initialization must be considered illegal. You have to copy buffers
> instead of moving pointers.
> Pointing pwf->bptr to a local variable as in your code is even worse. long
> BUFFER[10000] exists on the stack only and is vanishes as soon as read_wf()
> finishes. Thus giving a pointer to BUFFER to the outside world is generally
> illegal in C, not only in EPICS. I can't see why you did this. pwf->bptr is
> already pointing to a buffer of NELM longs. The record has set up the buffer
> for you. In your case, 10000 is probably the better value for NELM. Don't
> forget to check NELM in your code before looping to 10000 to avoid array
> bounds violations. You can also get a stack overflow on embedded systems
> like vxWorks when you use huge local arrays variables. Never do that.
Yes, I know that. I did use some global arrays in my actual device support, and
I was too desperated about the performance so I wrote the virtual
version without
thinking too much. I'm sorry about that.
> A similar thing happens inside subArray. The record first copies all input
> into is own buffer (instead of just looking at a pointer). For that, it
> needs enough bufferspace for the whole input, not only for its own region of
> interest. Thus, MALM must be the same size as the record INP is pointing to,
> 5000 (or 10000?) in your case. Then, subArray copies the interesting part
> into yet another buffer because of the way channel access only reads the
> bptr when connecting. All in all a huge waste of performance, but that's how
> it is at the moment.
> Dirk
> Zhichu Chen wrote:
>> Hi,
>> I've written a waveform support but I can't make it readable by other
>> records,
>> so I wrote a soft one like this:
>> static long read_wf(waveformRecord *pwf)
>> CALLBACK *pcallback=(CALLBACK *)(pwf->dpvt);
>> unsigned long i;
>> long BUFFER[10000];
>> for (i = 0 ; i < 1500 ; i++) {
>> BUFFER[i] = 10 + (i%2) ;
>> for (i = 1500 ; i < 4500 ; i++) {
>> BUFFER[i] = 510 + (i%2) ;
>> for (i = 4500 ; i < 10000 ; i++) {
>> long *pbuffer;
>> if(pwf->pact) {
>> pbuffer = BUFFER ;
>> pwf->nelm = pwf->nord = 5000;
>> pwf->bptr = pbuffer;
>> else{
>> if(pwf->disv<=0) return(2);
>> pwf->pact=TRUE;
>> callbackRequestProcessCallbackDelayed(
>> pcallback,pwf->prio,pwf,(double)pwf->disv);
>> pwf->pact=TRUE;
>> return 0;
>> and exported it to a device type as "SOFT" and wrote a db file like:
>> record (waveform, "wf") {
>> field(FTVL, "LONG")
>> field(SCAN, "1 second")
>> field(NELM, "5000")
>> field(DTYP, "SOFT")
>> record (subArray, "sa") {
>> field(INP, "wf.VAL")
>> field(FTVL, "LONG")
>> field(MALM, "100")
>> #field(INDX, "0")
>> field(NELM, "100")
>> the "wf" record gave a correct 5000 points emulated signal array but the
>> "sa"
>> record just gave me 100 zeros. I've tried some combinations in the DB file
>> like
>> some of you said it could be better to use "wf.VAL CA" in the INP field of
>> "sa"
>> or "wf.VAL CP" etc., but I have no luck.
>> Then I think maybe the waveform support needs modification. So can any of
>> you give me some advice about how to write the correct waveform support.
>> By the way, I put another soft waveform record and the subArray could read
>> it.
>> So basicly, it's not the problem of my EPICS release.
> Dr. Dirk Zimoch
> Paul Scherrer Institut, WBGB/006
> 5232 Villigen PSI, Switzerland
> Phone +41 56 310 5182
Best Regards
Chen
Zhi-chu Chen | Shanghai Synchrotron Radiation Facility
No. 2019 | Jialuo Rd. | Jiading | Shanghai | P.R. China
tel: 086 21 5955 3405 | zhichu.chen.googlepages.com
| www.sinap.ac.cn
- Weird waveform behavior Zhichu Chen
- Re: Weird waveform behavior Dirk Zimoch
RE: unhandled exception in timerQueue Jeff Hill
Re: Weird waveform behavior Tim Mooney
<2008>
<2008>
