Subject: registering IOC shell functions
To: [email protected]
Date: Wed, 11 Jun 2008 12:30:20 +0100
In the IOC applications developers guide, chapter 21, there are two ways
described for registering IOC shell functions. I'm having trouble
getting one of them working on Linux...
In the source file, I have:
epicsRegisterFunction(directoryWaitDef);
and in the included dbd file, I have:
function(directoryWaitDef)
I then build a static library containing the function.
When I build the IOC, the function seems to be built OK into the
executable. If I look inside it, I see:
nm -S bin/linux-x86/BL19I-MO-SIM-01 | grep directory
0804c44c 0000009f T directoryWaitDef
0804e74c 00000004 D pvar_func_register_func_directoryWaitDef
0804c4ec 0000002a t register_func_directoryWaitDef
However, when I start the IOC, the function isn't found.
I'm using EPICS 3.14.8.2.
The same procedure works fine when I build the same IOC for VxWorks.
It isn't a huge problem, because the other method described in the
manual works for my Linux IOC (using the registrar() function in the dbd
file). But the method above is significantly simpler in the source code.
Any ideas?
Matthew Pearson
DLS Controls
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
</FONT></DIV>
Re: registering IOC shell functions Eric Norum
uC5282 based RTEMS FlashSize error K.M Ha
80 MHz version of uCDIMM ColdFire 5282 Eric Norum
RE: 80 MHz version of uCDIMM ColdFire 5282 K.M Ha
Prev: RE: 80 MHz version of uCDIMM ColdFire 5282 K.M Ha
Next: Re: registering IOC shell functions Eric Norum
