On Freitag, 30. Mai 2008, Mathias Steiner wrote:
> All would be well if it were possible to change links -- either .FLNK or
> .OUT -- from within a subroutine. I've tried a couple of things without
> success. Just pasting the channel name into the "value" field of the
> union does not, and probably should not, work.
> Assigning a different value to a link by copying an input link doesn't
> work either:
> psub->flnk = psub->inpb;
> This isn't so clear to me, since they are both of type DBLINK. After
> all, I can "just" type the value into the .FLNK field of any channel
> using edm, and it'll work...
It works because this operation is going via Channel Access.
You can do the same from your subroutine: use the CA client library to
establish a channel to the FLNK (or whatever other link) field, then do a
ca_put with the new value. A very simple example for how to use CA (client)
is provides as a makeBaseApp template, just do
makeBaseApp.pl -t caClient
and look at caExample.c.
I am not sure whether the ca_context_create() call is necessary if you call
CA from a subroutine record, maybe the context has already been
initialized?
Cheers
Ben
- Re: subroutine, chaning links Tim Mooney
- subroutine, chaning links Mathias Steiner
<2008>
<2008>
