Subject: Re: IP Card Problems on the Acromag Carrier 9670
To: Darrell Nineham <[email protected]>
Cc: [email protected]
Date: Fri, 09 May 2008 09:44:44 -0500
Hi Darrell,
Darrell Nineham wrote:
Auto Clearing the Interrupt considerably reduces the ISR Loading and
eases the IP Code, so I am surprised it is not the default for 9670 /
drivers.
The drvXy9660.c carrier driver that was added to drvIpac version 2.9 (which I believe can control the Acromag 9670 card) does set the CSR_ACE bit of the Control/Status register. My guess is that you were probably investigating Andy Foster's original carrier driver which I haven't looked at recently — can you confirm that?
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
RE: IP Card Problems on the Acromag Carrier 9670 Darrell Nineham
Prev: IP Card Problems on the Acromag Carrier 9670 Darrell Nineham
Next: RE: IP Card Problems on the Acromag Carrier 9670 Darrell Nineham
