Subject: Re: Listing channels
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Wed, 07 May 2008 12:49:08 +0900
David Dudley wrote:
> Got 3 little questions:
> 1. Is there a method or application anywhere that can generate a list of
> the channels on a remote IOC?  I mean, a program I can point at the
> IOC's address and have it generate a list of all the channels on that
> unit?
It should be possible to write a small script to telnet to IOC and get a
list of records.
I also wrote an experimental soft-device support for waveform record.
It collect a list of records/record types/fields and return it as string
waveform(array) through channel access. Apparently you need to download
this device support (and waveform record) beforehand.
I will be very happy to send a source code if you are interested.
> David Dudley
Noboru Yamamoto
J-PARC control group/EPICS group
J-PARC center/KEK
JAPAN
Listing channels David Dudley
Prev: Listing channels David Dudley
Next: RE: Listing channels Mark Rivers
