Subject: RE: Beginners C++ questions
To: "Mark Rivers" <[email protected]>, <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Tue, 29 Apr 2008 09:17:28 -0700
Hi Mark,
I had similar problem when I was trying to create a shared lib (not epics).  It was fixed by checking the order of libraries to link.
Hope this can give you a hint.
Jinhu
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: Tuesday, April 29, 2008 8:23 AM
To: [email protected]; [email protected]
Subject: FW: Beginners C++ questions
Folks,
I'm having a simple problem with linking C++ on Linux that I wonder if you can help with.
Here's the problem.
- I have a C++ base class and a number of derived classes.  If the base class is in the same library as the derived classes everything is fine.
However, if the base class is in a different library from the derived classes, then it compiles fine (because it finds the header file), but it fails at link time.
My base class has methods like the following:
/* Constructor */
asynParamBase::asynParamBase(const char *portName, int maxAddr, int
paramTableSize)
    : maxAddr(maxAddr){
Since that is not declared static, if it were a C function the linker would find it even if it were in a different library.  However, when I try to link this base class which is used by a derived class in another library I get the following error:
../NDPluginBase.cpp:454: undefined reference to `asynParamBase::asynParamBase[not-in-charge](char const*, int, int) '../../../lib/linux-x86//libADPlugin.a
(NDPluginBase.o)(.text+0xfff): In function `NDPluginBase::NDPluginBase[in-charge](char const*, int, int, char const*, int, int, int)':
However, if I force the linker to include the module that includes the base class source code by adding the following lines to the beginning of
it:
/* This is for testing */
#include <epicsExport.h>
int asynParamBaseDebug=0;
epicsExportAddress(int, asynParamBaseDebug);
and then add this line to the .dbd file:
variable(asynParamBaseDebug,int)
then it links OK.
How do I get the linker to pull in the module with the base class definition without having to force it with that global definition?
Andrew Johnson suggested putting the keyword epicsShareClass before the class definition.  I tried that, but interestingly it links fine on Windows with or without that keyword, but fails on Linux with or without the keyword.
RE: Beginners C++ questions Mark Rivers
FW: Beginners C++ questions Mark Rivers
Prev: FW: Beginners C++ questions Mark Rivers
Next: RE: Beginners C++ questions Mark Rivers
