Subject: Re: StreamDevice protocol question
To: tech-talk <[email protected]>
Date: Fri, 18 Apr 2008 11:51:26 -0400
For what it's worth, the response of the device seems to be for example
<CR> <some number> ;
We changed the stream device terminator to ";", and from then on it
was possible to parse the CR in the response string.
-Kay
On Apr 18, 2008, at 10:45 AM, Geng, Xiaosong wrote:
I have a Selective Radiation Meter SR-3000, which has serial interface.
I am trying to get serial set/get with StreamDevice works, the control/set commands works fine, but Query response commands are not working yet.
Here are my protocol file, db, and error messages from IOC:
Protocol:
locktimeout = 5000;
terminator   = CR LF;
replytimeout = 1000;
readtimeout  = 1000;
extrainput   = Ignore;
@init{out " ";}
# set commands here works fine
# but get commands...
fmin_get        { out "F_MIN?;"; in "\13, %f"; }
fmax_get        { out "F_MAX?;"; in "\r, %f"; }
mode_get { out "MODE?;" ; in "%s" ; }
spectrum_get { out "SPEC?;" ; separator="\13"; in "spectrum = (% f)";
db:
record(ai, "$(S)_$(SS):$(DEV)$(N):FMIN_Get") {
 field(DESC, FMIN Reading")
#  field(SCAN, "10 second")
 field(DTYP, "stream")
 field(INP, "@srm3000.protocol fmin_get $(PORT) 0")
 field(PREC, "2")
 field(HOPR, "")
 field(LOPR, "")
 field(EGU, "Hz")
record(ai, "$(S)_$(SS):$(DEV)$(N):FMAX_Get") {
 field(DESC, "FMAX Reading")
 field(INP, "@srm3000.protocol fmax_get $(PORT) 0")
 field(PREC, "2")
 field(HOPR, "")
 field(LOPR, "")
 field(EGU, "Hz")
record (waveform, "$(S)_$(SS):$(DEV)$(N):Spectrum_Get")
   field (DTYP, "stream")
   field (INP,  "@srm3000.protocol spectrum_get $(PORT) 0")
   field (FTVL, "DOUBLE")
   field (NELM, "10000")
error message from the IOC:
2008/04/16 16:38:49.592 SCL_HPRF:SRM1:FMIN: Timeout after reading 11 bytes "<0d>850000000;"
StreamDevice protocol question Geng, Xiaosong
Re: StreamDevice protocol question Geng, Xiaosong
Prev: Re: StreamDevice protocol question Geng, Xiaosong
Next: epics IOC and gun screen and copy/scrollback mode John Dobbins
