I don't know about the 8 file limitation. Tim Mooney may know about that.
pass0 is like setting VAL in the db file. pass1 is not like a caput, it does not cause the record to process, because it is all still done before iocInit. It has to do with the timing relative to when links have been established I think.
vxWorks typically has no local disk, and NFS is the preferred file system. For computer-based IOC you don't need to worry about, you can just save to a local disk.
Sent: Wed 4/16/2008 7:11 PM
To: Mark Rivers
Cc: epics
Subject: RE: autosave issues
Mark,
I implemented autosave relatively easily thanks to the documentation.
For the set_passX_restoreFile functions, it says that only 8 files can
be restored at each pass.
This is rather an important limitation if I have a restore file per
device (and not 1 per ioc). Is this limitation still applicable?
Is doing a restore at pass0 equivalent to setting the VAL fields in the
db file? For pass1, is it equivalent to having several caputs on a
running ioc?
Why do they recommend saving vxWorks station over NFS? I assume it is
only because of a storage space limitation. If that is the case, then it
is not applicable for computer-based IOC. Isn't it?
E
On Tue, 2008-04-15 at 21:22 -0500, Mark Rivers wrote:
> The problems are probably less frequent than that. And a beamline might be 4 IOCs.
> The issues tend to arise during power or network failures when the vxWorks VME IOC is in the middle of saving the file via NFS.
> There are safeguards now in place that make this much less likely. And there are backup files created by the autosave system that can be recovered from.
> Mark
> ________________________________
> From: [email protected] on behalf of Emmanuel Mayssat
> Sent: Tue 4/15/2008 8:35 PM
> To: epics
> Subject: autosave issues
> Hello again,
> I was looking at autosave record/functions.
> I read that APS is experiencing at least 1 autosave issue per beamline,
> per year. Can anyone expend on that?
> I assume that files are being corrupted or such...
> How could that happen?
> Emmanuel
- Re: autosave issues Tim Mooney
- autosave issues Emmanuel Mayssat
- RE: autosave issues Mark Rivers
- RE: autosave issues Emmanuel Mayssat
<2008>
<2008>
