To fix this, I propose to add this patch to the next base release:
aragon: .../configure/tools > cvs diff -u -r epics_R3_14_9 convertRelease.pl
Index: convertRelease.pl
RCS
file: /opt/repositories/controls/epics/base/3.14/configure/tools/convertRelease.pl,v
retrieving revision 1.1.1.8
retrieving revision 1.3
diff -u -r1.1.1.8 -r1.3
--- convertRelease.pl 1 Mar 2007 11:31:42 -0000 1.1.1.8
+++ convertRelease.pl 7 Mar 2007 11:16:18 -0000 1.3
@@ -220,6 +220,11 @@
next unless (-d "$path/dbd");
print OUT "RELEASE_DBDFLAGS += -I \$(strip \$($app))/dbd\n";
+ foreach my $app (@includes) {
+ my $path = $macros{$app};
+ next unless (-d "$path/db");
+ print OUT "RELEASE_DBFLAGS += -I\$(strip \$($app))/db\n";
close OUT;
On Tuesday 15 April 2008 23:23, John Dobbins wrote:
> Stephanie,
> If I change
> #13 Makefile to:
> TOP=../../..
> include $(TOP)/configure/CONFIG
> DB = second.db
> include $(TOP)/configure/RULES
> DBFLAGS += $(TOP)/db
> but I can't seem to get DBFLAGS to appear automatically.
> Is there a way to debug the RULES building part of the build process?
> John
> Allison, Stephanie wrote:
> > Hi John,
> > Your rule for inflating the database isn't properly using DBFLAGS so it
> > doesn't have the directories with "db" in the include list. Is it
> > possible you are using a rule that is different from the one in
> > base/configure/RULES.Db?
> > Here is an example from my build (I have several modules included in my
> > RELEASE which is why the long list of potential areas to find database
> > files):
> > Inflating database from ../evrEventAll.substitutions
> > /nfs/slac/g/lcls/build/epics/extensions/extensions-R3-14-8-2/bin/linux-
> >x86/msi -I. -I.. -I ../../../../db -I
> > /nfs/slac/g/lcls/build/epics/modules/generalTime/generalTime-R1-2-1/db
> > -I /nfs/slac/g/lcls/build/epics/modules/sSubRecord/sSubRecord-R1-0-1/db
> > -I /nfs/slac/g/lcls/build/epics/modules/miscUtils/miscUtils-R1-0-1/db
> > -I /nfs/slac/g/lcls/build/epics/base/base-R3-14-8-2-lcls2/db
> > -I../O.Common -S../evrEventAll.substitutions > msi.tmp
> > mv msi.tmp ../O.Common/evrEventAll.db
> > If you are using your own rule, you may need to add the "db" in front
> > of the file name. For example:
> > file db/firstAll.db
> > pattern { DEVICE }
> > { device1 }
> > { device2 }
> > {device30}
> > Stephanie
> >> -----Original Message-----
> >> From: John Dobbins [mailto:[email protected]]
> >> Sent: Tuesday, April 15, 2008 12:21 PM
> >> To: Allison, Stephanie
> >> Cc: EPICS Tech-Talk
> >> Subject: Re: multiple levels of substitution in msi
> >> Allison,
> >> Using your suggestion (from January) I tried unsuccessfully
> >> to get MSI to do
> >> multiple levels of substitution. I am using 3.14.9 but I
> >> assume that is not the
> >> issue.
> >> Setup:
> >> #1 xxx
> >> #2 Makefile
> >> #3 configure/
> >> #4 iocBoot/
> >> #5 xxxApp/
> >> #6 Makefile
> >> #7 Db/
> >> #8 first/
> >> #9 Makefile
> >> #10 firstAll.substitutions
> >> #11 firstAll.template
> >> #12 second/
> >> #13 Makefile
> >> #14 second.substitutions
> >> #15 src/
> >> Fails with:
> >> Inflating database from ../second.substitutions
> >> msi -I. -I.. -I../O.Common -S../second.substitutions > msi.tmp
> >> Could not open firstAll.db
> >> firstAll.db exists but not in any of the places MSI is
> >> looking. How do I get
> >> MSI to find it?
> >> Details:
> >> #6 Makefile is:
> >> TOP=../..
> >> DIRS += first
> >> DIRS += second
> >> include $(TOP)/configure/RULES_DIRS
> >> #9 Makefile is:
> >> TOP=../../..
> >> DB = firstAll.db
> >> #13 Makefile is:
> >> TOP=../../..
> >> DB = second.db
> >> Thanks,
> >> John Dobbins
> >> Cornell University
> >> Lab for Elementary Particle Physics
> >>> Hi John,
> >>>> Is there a way to get MSI to deal with multiple levels of
> >>>> substitution?
> >>> I divide my Db directory into sub-directories and build
> >> them in the proper order. For example:
> >>> xxxApp/Db/first contains Makefile, first.db, and
> >> firstAll.substitions:
> >>> Makefile has:
> >>> DB += firstAll.db
> >>> firstAll.substitutions which looks something like this:
> >>> file first.db
> >>> pattern { DEV , CARD , NAME , ID
> >> ,P0,P1,P2,P3,P4,P5,P6,P7,P8,P9,P10,P11,P12,P13,VME}
> >>> { $(DEVICE) , 0 , NAME1 , 1 , 0, 0, 0,
> >> 0, 0, 0, 0, 0, 0, 0, 0 , 0 , 0 , 0 , 1 }
> >>> { $(DEVICE) , 0 , NAME2 , 2 , 1, 0, 0,
> >>> { $(DEVICE) , 0 , NAME15 , 12 , 0, 0, 0,
> >> 0, 0, 0, 0, 0, 0, 0, 0 , 0 , 0 , 1 , 1 }
> >>> xxxApp/Db/second contains Makefile, second.substitutions:
> >>> Makefile has:
> >>> DB += second.db
> >>> second.substitutions looks something like this:
> >>> file firstAll.db
> >>> pattern { DEVICE }
> >>> { device1 }
> >>> { device2 }
> >>> {device30}
> >>> and xxxApp/Db/Makefile looks like:
> >>> TOP = ../..
> >>> # first must be first since second will need for the
> >> .db file created by first
> >>> DIRS += first
> >>> DIRS += second
> >>> The RULES.Db files that come with epics 3.14.8.2 will do
> >> the MSI properly - I don't think we had to change RULES.Db for this.
> >>> If you don't like sub-directories, just create more *Db
> >> directories under xxxApp:
> >>> xxxApp/CommonDb1
> >>> xxxApp/CommonDb2
> >>> xxxApp/Db (which depends on CommonDb1 and CommonDb2
> >> being built first)
> >>> xxxApp/Makefile must enforce proper build order
> >>> Note there is a bug in the RULES somewhere that requires
> >> the "{" that comes after the "file xxxx.db" to be on the next
> >> line if xxxx.db comes from another module listed in your RELEASE file.
> >>> Doesn't work:
> >>> file xxxx.db {
> >>> Works:
> >>> file xxxx.db
> >>> Hope this helps more than confuses...
> >>> Stephanie Allison
"Programming = Mathematics + Murphy's Law" (E.W.Dijkstra)
- RE: multiple levels of substitution in msi Allison, Stephanie
- multiple levels of substitution in msi John Dobbins
- Re: multiple levels of substitution in msi John Dobbins
RE: autosave issues Mark Rivers
Channel Archiver building problem in Make Install command Tasaddaq Ali Khan
<2008>
<2008>
