Subject: Re: edm font file
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Tue, 15 Apr 2008 17:28:25 -0700
1/ X forward is set correctly with ssh
2/ I made an error when reporting the local error.
I found that the local error is due to the edm file I am opening.
The edl file I was looking at has been developed at another site.
There is some information about this in the documentation, but I cannot
really make sense of it.
How are fonts expended/matched?
How is fonts.list populated?
(I always used the one that came with the edm tar archive.)
When I start edm (without any edl file) locally it works.
When I do this through ssh, it reports a font error.
Font init failed - abort
Update:
If I ssh from a machine that has the same OS (fedora core 4), the error
disappear!!! When I ssh from a RH8.0 machine, edm report the Font init
failed - abort error.
Huh?!?!?
On Tue, 2008-04-15 at 18:31 -0400, J. Lewis Muir wrote:
> On 4/15/08 6:09 PM, Emmanuel Mayssat wrote:
> > Apparently the issue is related to whether I run edm remotely or
> > locally.
> Hi, Emmanuel.
> I don't have specific knowledge about EDM, but:
> * Have you installed the fonts such that they are available to the X11
>   server being used to display your EDM application?
> * What command(s) are you using to log into the computer remotely and
>   set up your X11 environment?  Are you using the ssh that comes with
>   OpenSSH, and are you using it with the "-X" option?  Have you tried
>   using the "-Y" option instead?
> Lewis
Re: edm font file Emmanuel Mayssat
Re: edm font file J. Lewis Muir
Prev: Re: edm font file J. Lewis Muir
Next: Re: edm font file Emmanuel Mayssat
