Subject: Re: multiple levels of substitution in msi
To: "Allison, Stephanie" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 15 Apr 2008 15:21:16 -0400
Allison,
Using your suggestion (from January) I tried unsuccessfully to get MSI to do multiple levels of substitution. I am using 3.14.9 but I assume that is not the issue.
Setup:
#1  xxx
#2     Makefile
#3     configure/
#4     iocBoot/
#5     xxxApp/
#6        Makefile
#7        Db/
#8           first/
#9              Makefile
#10             firstAll.substitutions
#11             firstAll.template
#12          second/
#13             Makefile
#14             second.substitutions
#15       src/
Fails with:
   Inflating database from ../second.substitutions
   msi   -I. -I.. -I../O.Common -S../second.substitutions  > msi.tmp
   Could not open firstAll.db
firstAll.db exists but not in any of the places MSI is looking. How do I get MSI to find it?
Details:
#6 Makefile is:
   TOP=../..
   include $(TOP)/configure/CONFIG
   DIRS += first
   DIRS += second
include $(TOP)/configure/RULES_DIRS
#9 Makefile is:
   TOP=../../..
DB = firstAll.db
#13 Makefile is:
   TOP=../../..
DB = second.db
John Dobbins
Cornell University
Lab for Elementary Particle Physics
Allison, Stephanie wrote:
Hi John,
Is there a way to get MSI to deal with multiple levels of substitution?
I divide my Db directory into sub-directories and build them in the proper order. For example:
xxxApp/Db/first contains Makefile, first.db, and firstAll.substitions:
Makefile has:
DB += firstAll.db
firstAll.substitutions which looks something like this:
file first.db {
pattern { DEV , CARD , NAME , ID ,P0,P1,P2,P3,P4,P5,P6,P7,P8,P9,P10,P11,P12,P13,VME}
{ $(DEVICE) , 0 , NAME1 , 1 , 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 , 0 , 0 , 0 , 1 }
{ $(DEVICE) , 0 , NAME2 , 2 , 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 , 0 , 0 , 0 , 1 }
{ $(DEVICE) , 0 , NAME15 , 12 , 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 , 0 , 0 , 1 , 1 }
xxxApp/Db/second contains Makefile, second.substitutions:
Makefile has:
DB += second.db
second.substitutions looks something like this:
file firstAll.db {
pattern { DEVICE }
{ device1 }
{ device2 }
{device30}
and xxxApp/Db/Makefile looks like:
TOP = ../..
# first must be first since second will need for the .db file created by first
DIRS += first DIRS += second
The RULES.Db files that come with epics 3.14.8.2 will do the MSI properly - I don't think we had to change RULES.Db for this.
If you don't like sub-directories, just create more *Db directories under xxxApp:
	xxxApp/CommonDb1
	xxxApp/CommonDb2
	xxxApp/Db  (which depends on CommonDb1 and CommonDb2 being built first)
	xxxApp/Makefile must enforce proper build order
Note there is a bug in the RULES somewhere that requires the "{" that comes after the "file xxxx.db" to be on the next line if xxxx.db comes from another module listed in your RELEASE file.
Doesn't work:
file xxxx.db {
Works: file xxxx.db
Hope this helps more than confuses...
Stephanie Allison
RE: multiple levels of substitution in msi Allison, Stephanie
multiple levels of substitution in msi John Dobbins
Prev: edm font file Emmanuel Mayssat
Next: RE: multiple levels of substitution in msi Allison, Stephanie
Prev: RE: multiple levels of substitution in msi Allison, Stephanie
