Emmanuel Mayssat wrote:
Hello,
Some of you may be familiar with the cavget alternative to caget.
I am currently trying to cavget a waveform record.
To my surprise, this utility only returns the last value of the
waveform. Is there an option/trick to have cavget, like caget, return
the entire waveform ?
Emmanuel
cavget does not handle waveforms. It returns the first element in the
waveform only. What I would suggest is that you use:
sddswget -PVnames=BRF:K5:WaveformCh8 -pipe=out | sdds2stream -pipe=in
-col=Waveform
--Bob
- cavget of a waveform Emmanuel Mayssat
RE: Windows EPICS problem Mark Rivers
<2008>
Channel Archiver compiling problem with Xerces XML Library Tasaddaq Ali Khan
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
