Subject: RE: compiling error:expected constructor, destructor, or type conversion before "(" token
To: '黄思婷' <[email protected]>, "'tech-talk'" <[email protected]>
Date: Fri, 4 Apr 2008 17:08:51 +0900
It may be usefull if you can give detailed information about your situation.
Do you tend to wrap the driver provided by the vender in your EPICS application?
Is there any existing EPICS device driver for your hardware?
Another is to develop your own EPICS device driver instead of wrapping the vender's
if you have enough information.
Guobao
Sent: 2008 - 4 - 4 4:43 PM
To: tech-talk
Subject: compiling error:expected constructor, destructor,or type conversion before "(" token
Dear tech-talk,
I'm trying to transplant a device driver to EPICS and develop some device suport of it. But while compiling the codes, there is such error:
../../include/Interface.h:44: error: expected constructor,destructor,or type conversion before "(" token
The device driver is provided along with the hardware in the format of .so and .h.
The Interface.h file contains some driver function declarations.
I wonder if the reason is that the declaration and definition of the class are not together. But the function call of the device driver outside EPICS works normally.
How can I solve this problem?
Thanks a lot!
2008-04-04
Siting Huang
compiling error:expected constructor, destructor, or type conversion before "(" token 黄思婷
Prev: compiling error:expected constructor, destructor, or type conversion before "(" token 黄思婷
Next: Re: compiling error:expected constructor, destructor, or type conversion before "(" token Stefan Heim
