In the startup are the lines: hostAdd "devnet", "129.57.228.1" # use this for IOC's which are on 129.57.{228,229,230,231} routeAdd "0.0.0.0", "devnet" I couldn't run tcpdump but I could run casw on the 236 subnet and I'm getting no broadcasts from iocfb1. I can ping from each IOC and see the other IOC. When I switch between different kernels and EPICS I've had to burn the flash to go from tornado 1.0.1 to 2.2.1. And then change links that point to the different versions. My original thought was there is some parameter in the kernel or epics that I'm missing because I am communicating from the 230 to the 236 network if both IOCs are running epics 3.13 and tornado 1.0.1. And within a subnet I can communicate regardless of the kernel or EPICS version. -Sue Paul Sichta wrote: I've added the following to the st.cmd boot file. The IP is the IP of the gateway for the subnet of the IOC server. Geoff Savage wrote: Can you run tcpdump on a linux box in the 236 subnet to look for the broadcast from iocfb1?
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
