I have a curious problem concerning multi-subnet connectivity when converting from Epics 3.13.2 to Epics 3.14.8.2. Using the same network setup and database the 3.13 db can communicate across subnets while the 3.14 db gets a link error. Again, if iocfb1 is running Epics 3.13.2 and Tornado 1.0.1 then there is no link error and there's communication between the two subnets, but if iocfb1 is running Epics 3.14.8.2 and Tornado 2.2.1 then I get a link error. Any suggestions? Here is my setup: iocmc1 129.57.236.20 iocfb1 129.57.230.101 Epics 3.13.2 Epics 3.14.8.2 mvme-2700 mvme-2700 Tornado 1.0.1 Tornado 2.2.1 database record on iocfb1 129.57.230.101 record(ai,"iocfb1:mc1com1") { field(DESC,"analog input record") field(SCAN,"Passive") field(INP,"iocmc1:heartbeat.VAL") } database record on iocmc1 129.57.236.20 record(calc,"iocmc1:heartbeat") { field(DESC,"calculation record") field(SCAN,"1 second") } resource.def file for iocfb1 putenv ("EPICS_CA_AUTO_ADDR_LIST = YES") putenv ("EPICS_CA_ADDR_LIST = 129.57.239.255") bootParams: boot device : dc0 processor number : 0 host name : devfs file name : /devsite/op/iocs/iocfb1/vx/vxWorks.st inet on ethernet (e) : 129.57.230.101:fffffc00 inet on backplane (b): host inet (h) : 129.57.228.40 gateway inet (g) : 129.57.228.1 user (u) : vxwrks ftp password (pw) (blank = use rsh): flags (f) : 0x80 target name (tn) : iocfb1 startup script (s) : /devsite/op/iocs/iocfb1/startup resource.def file for iocmc1 EPICS_CA_ADDR_LIST DBF_STRING "129.57.211.255 129.57.243.255 129.57.255.10" bootParams: boot device : dc processor number : 0 host name : opsfs file name : /opssite/op/iocs/iocmc1/vx/vxWorks.st inet on ethernet (e) : 129.57.236.20:fffffc00 host inet (h) : 129.57.236.40 user (u) : vxwrks flags (f) : 0x80 target name (tn) : iocmc1 startup script (s) : /opssite/op/iocs/iocmc1/startup
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
