Subject: Re: StringIn and StringOut
Cc: [email protected]
Date: Mon, 24 Mar 2008 11:02:24 -0600
Andrew Johnson wrote:
Hi David,
David Dudley wrote:
Now that we're actually starting to get serious about EPICS, I've got people crawling all over the place wanting access to information in the remotes, and wanting to get trained on EPICS. Andrew, you really need to get the guys to fix the website so the softTV training videos are available. I get intermittent connection errors when I try to open the RealVideo streams. Sometimes it works ...for a while..., sometimes it doesn't.
As of a week ago I thought the problem was fixed — our sysadmins replaced the rtsp proxy in the firewall with an ip filter. Have you tried it since 3/17?
Does anybody know if it's possible to transcode RealVideo files into any widely used non-proprietary formats, and if so what tools I need to do that?
Hi Andrew,
I believe mencoder may be able to do the transcode. If you have mplayer installed, chances are that mencoder will be too.
-- dc
StringIn and StringOut David Dudley
Re: StringIn and StringOut Andrew Johnson
Prev: Re: StringIn and StringOut Andrew Johnson
Next: Re: StringIn and StringOut J. Lewis Muir
