Yes, I'd be interested. That seems like it should be a fairly common
item. I'm surprised something similar isn't a part of the base system.
I really sort of expected it to already be there.
David
>>> "Schoeneburg, Bernd" <[email protected]> 3/20/2008 10:55 AM
I have created a "strtabRecord" (string Table Record) for exactly this
problem. It uses an externally loaded string library. The library
contains the string tables. Each entry consists of the integer number,
a
string and an alarm severirty. If the input number is not defined in
the
table, the record will display the number instead and the alarm
severity
will be set to the predefined (UNSV). You can select a different table
during runtime. Connecting the library works similar to the subroutine
record. If you are interested I can send you the sources.
Bernd
David Dudley schrieb:
> At a remote site, I have a backup generator that I am monitoring
through
> an EPICS IOC. When the generator faults offline, it sends a numeric
> fault to the IOC of what the particular error is.
> I want to display a text error message instead of the fault number
on
> my edm display. The generator generates 1 of 235 errors. How do I
> convert the error number into a text message, and return it through a
ca
> link? The error number I can easily return, but is there a way to
build
> a 'lookup table' in EPICS?
> Also, is there a way to have the IOC send out an email alert when
the
> system faults? The site is around 50 miles from my office, but only
> around 5 miles from our nearest service person. I would rather have
the
> system email the service person with errors like "Unit Overheat", or
> "Unit Maintenance Preset" or other errors, rather than me have to
look
> up the error code and then figure out who to notify.
> David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
- EPICS: Selecting a Text Error Message David Dudley
- Re: EPICS: Selecting a Text Error Message Schoeneburg, Bernd
Re: EPICS: Selecting a Text Error Message Ben Franksen
<2008>
<2008>
