Subject: Re: sysAtReboot and epicsExit
To: Chris Slominski <[email protected]>
Cc: [email protected]
Date: Wed, 19 Mar 2008 10:06:36 -0500
Hi Chris,
Chris Slominski wrote:
ld<systemO/system.munch
sysAtReboot not found. epicsExit will not be called by reboot.
We have converted from VxWorks 5.2 to 5.5, and from epics 3.13.3 to 3.14.8.2 We get this diagnostic on startup of our IOCs when epics static object constructors are executed. I assume epics is trying to register some kind of shutdown handler. I am not familiar with sysAtReboot and don’t know why it is missing. Is it a VxWorks function? We do have odd problems on warm reboots and I suspect needed reboot hooks are not being called. What do I need to do?
sysAtReboot() is a routine you need to add to your vxWorks BSP/boot image which provides a way to get around the fundamental design flaw that Wind River made with their rebootHook facility — that the hook routines are called in the same order that they are registered rather than in reverse order. This means that the TCP/IP network stack shuts down before the application running on top of it ever gets notified, so it is not possible for the application to close any network connections nicely. The sysAtReboot facility registers its rebootHook *before* the network stack gets initialized, so our epicsAtExit() routines now get called before the network gets taken off-line.
I described the BSP changes you need in this tech-talk message: http://www.aps.anl.gov/epics/tech-talk/2005/msg00004.php
If you have any questions about that code just let me know.
If you can't make those changes immediately, you can add this line to the top of your st.cmd scripts which will at least ensure that the epicsAtExit() routines get called, but they still won't be able to clean up any network sockets.
rebootHookAdd(epicsExitCallAtExits)
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
sysAtReboot and epicsExit Chris Slominski
Prev: Re: Severity of I/O interrupt records Tim Mooney
Next: EPICS: Selecting a Text Error Message David Dudley
Prev: sysAtReboot and epicsExit Chris Slominski
