Subject: Re: Building MEDM
To: [email protected]
Date: Tue, 11 Mar 2008 10:17:33 -0400
On 3/11/08 9:35 AM, David Dudley wrote:
> Oh, so it's that file.  I was looking for something in base.  I have
> that file, and I have the settings set correctly in it.  However, when I
> get over to the build for MEDM, the variables appear to be blank.  This
> is only happening on MEDM, not on any of the other extensions.
> David
Hi, David.
What version of EPICS base are you using?
Are you using the new "Extensions Top" config files from
  http://www.aps.anl.gov/epics/extensions/configure/index.php
What version of MEDM are you trying to compile?
Could you send the commands you're using to compile MEDM and their output?
Lewis
J. Lewis Muir
Software Engineer
CARS/IMCA-CAT
Re: Building MEDM David Dudley
RE: Building MEDM Hammonds, John P.
RE: Building MEDM David Dudley
Prev: RE: Building MEDM David Dudley
Next: Re: Building MEDM David Dudley
