Subject: Re: Problem with gateway
To: Dehong Zhang <[email protected]>
Cc: [email protected]
Date: Tue, 11 Mar 2008 07:41:39 -0500
Hi Dehong,
On the client side try setting the environment variable:
EPICS_CA_SERVER_PORT 6064
before starting the client or trying, for example:
caget gateway.connected
Hope this helps,
Marty
Dehong Zhang wrote:
I am trying to set up a gateway (v2_0_2_1 with epics 3_14_8), am having
trouble.  It complains about:
CAC: Unable to connect because "Invalid argument"
Mar 10 11:39:19 !!! Errlog message received (message is above)
My pv list is called "gateway.pvlist".  It contains:
EVALUATION ORDER ALLOW, DENY
Crate1.*        ALLOW
bpm36.*          ALLOW
# Convert old Gateway internal process variable names
gateway\.\(.*\)            ALIAS     gateway:\1
gateway\.\(.*\)Flag        ALIAS     gateway:\1Flag          GatewayAdmin
gateway\.alive             ALIAS     gateway:connected
gateway\.postEventRate     ALIAS     gateway:clientPostRate
The access list is called "gateway.access".  It has:
ASG(DEFAULT) {
   RULE(1,READ)
The command I use is:
./gateway -sport 6064 -cport 5065 -pvlist ./gateway.pvlist -prefix "gateway" -access ./gateway.access
I cannot even access the internal PVs like:
gateway:pvtotal
gateway:active
Please enlighten me.
Thanks and best regards,
Dehong
Re: Problem with gateway Dehong Zhang
Prev: RE: Building MEDM Hammonds, John P.
Next: RE: Building MEDM David Dudley
Prev: Problem with gateway Dehong Zhang
Next: Re: Problem with gateway Dehong Zhang
