Subject: Problem with gateway
To: [email protected]
Date: Mon, 10 Mar 2008 13:37:33 -0500
I am trying to set up a gateway (v2_0_2_1 with epics 3_14_8), am having
trouble.  It complains about:
CAC: Unable to connect because "Invalid argument"
Mar 10 11:39:19 !!! Errlog message received (message is above)
My pv list is called "gateway.pvlist".  It contains:
EVALUATION ORDER ALLOW, DENY
Crate1.*        ALLOW
bpm36.*          ALLOW
# Convert old Gateway internal process variable names
gateway\.\(.*\)            ALIAS     gateway:\1
gateway\.\(.*\)Flag        ALIAS     gateway:\1Flag          GatewayAdmin
gateway\.alive             ALIAS     gateway:connected
gateway\.postEventRate     ALIAS     gateway:clientPostRate
The access list is called "gateway.access".  It has:
ASG(DEFAULT) {
   RULE(1,READ)
The command I use is:
./gateway -sport 6064 -cport 5065 -pvlist ./gateway.pvlist -prefix "gateway" -access ./gateway.access
I cannot even access the internal PVs like:
gateway:pvtotal
gateway:active
Please enlighten me.
Thanks and best regards,
Dehong
Re: Problem with gateway Martin L. Smith
Prev: Re: EPICS alarm handler server? Matthias Clausen
Next: PLC Ethernet Driver for the IDEC MicroLogix 1100 Luchini, Kristi
Prev: Re: EPICS alarm handler server? Maren Purves
Next: Re: Problem with gateway Martin L. Smith
