Subject: Re: EDM: x-y graph questions
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Fri, 07 Mar 2008 06:55:52 -0800
David,
As Maren mentioned, Medm has strip charts.
The strip charts widget:
* display an ai-type record (single value PV) instead of a waveform
* uses time on its X axis
* does not make previous sample values accessible in epics database
* cannot be stopped
Not sure it fits all of your requirements, but it may be an option.
E
On Thu, 2008-03-06 at 14:34 -0600, David Dudley wrote:
> Is it possible to create a sliding y-graph in EDM?
> Whatever I do, the display collects the number of samples I have
> indicated, and then stops.  I need time-based scrolling graphs for a
> display I'm doing (I need to display 3 or 4 of them on the page).
> David
EDM: x-y graph questions David Dudley
Prev: Software Systems Engineer position at Diamond Light Source Lizzie McCoy
Next: sequence compilation in multi-device IOC Emmanuel Mayssat
Prev: Re: EDM: x-y graph questions Maren Purves
Next: Software Systems Engineer position at Diamond Light Source Lizzie McCoy
